Thread: Is there still a replacement or refills for the PS233 Test Kit?
    May 2014
    NW USA
    Default Is there still a replacement or refills for the PS233 Test Kit?
    I have a PS233 test kit, but it is (obviously) old. I need to either get refills or a new kit.
    I see mention of a PS234 kit, but it looks like PoolForum no longer sells this stuff.
    Is that correct?
    I see recommendations for test kits, I'll pursue that unless I hear otherwise...
    Default Re: Is there still a replacement or refills for the PS233 Test Kit?
    The one we recommend is the Taylor K2006 or 2006C (better buy). Click on the test kit link in my signature below and it will take you to an Amazon page where you can get it. Any purchases made from Amazon that start with that link (even if it is not pool stuff), earn a small percentage for the forum which helps us keep the forum alive and able to help people.
    (And, you are right, the forum no longer sells kits.)
    Welcome to the Pool Forum! Although........ if you have a PS233, you must have been around here for awhile. ??
    The reagents in the PS233 *are* Taylor reagents, just in different bottles. You can get the K2006C (2oz bottles) if you need everything, or you can buy the specific Taylor refills you need.
    The bottles (except for CYA) from both the PS233 and Taylor have pop-out dropper tips that can be removed by holding the bottle and pressing on the side of the tip with your thumb.
    May 2014
    NW USA
    Thank you. I am actually a returning member. The question was real, but I also needed to ask one to validate the new account.
    Quote Originally Posted by Schwimmer2 View Post
    That is what I suspected. What was your username before?
    May 2014
    NW USA
    Schwimmer
  1. Amato Inc. test kit refills
    By AnnaK in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-29-2011, 02:17 PM
  2. Discrepency btw store's H20 test and PS233
    By 22wendylou in forum DPD-FAS based testing
    Last Post: 07-10-2010, 11:23 PM
  3. PS233 test kit and CYA test question
    By mshumack in forum DPD-FAS based testing
    Last Post: 06-06-2006, 11:28 PM
  4. PS233 test (1st this year)
    By cvoytek in forum DPD-FAS based testing
    Last Post: 05-29-2006, 11:35 AM
  5. 1st Test Results with my PS233
    By Phulish in forum DPD-FAS based testing
    Last Post: 05-25-2006, 01:12 PM
