This Hayward Power-Flo pump should perform well for you:Hayward SP15922S Power-Flo Matrix 2-SpeedWhat I can't tell, is whether the pump comes with a 2-speed toggle, or whether you have to add that to the wiring. You may have to call Hayward for that information:(908) 355-7995 (U.S.)This time of year, plan to be on hold for awhile when you call.
Mon-Fri, 8 AM – 5 PM
You may also need to put some sort of valve on the backwash line, to avoid blowing sand out -- just check during your 2nd backwash to see if you are losing sand. (You'll lose some fine particles during your 1st backwash, regardless.) Also, the pump may be a bit oversized on high speed, so run only on low, unless you need to run on high.
