Thread: Summer Start up -- need bleach dose for a 25k gallon pool
    May 2014
    Texas
    Default Summer Start up -- need bleach dose for a 25k gallon pool
    25,000 gal. pool need to know how much bleach to begin
    BigDave's Avatar
    Default Re: Summer Start up -- need bleach dose for a 25k gallon pool
    We'll need to know more about the pool. Is the water new? Plaster or vinyl surface? In ground or above? What kind of filter? How does the water look now?
    Also, a good test kit is essential to effective, efficient poolcare. We recommend the Taylor K-2006 or K-2006C (bigger bottles, better value). If you order one through the links on this page:http://pool9.net/test the forum gets some coin to keep the lights on. You'll have to copy the URL then log out and paste it into your browser to use it until your account is reviewed.
    Read all you can in these forums, especially the stickies and at poolsolutions.com to learn about Safe, efficient and effective pool care. We're always here to help.
    . . . membership upgraded.
    (1) standard 121oz jug of 8% Walmart bleach will add about 3 ppm of chlorine to your pool
  1. High AK, Is it ok to start with the bleach.
    By bssage in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 04-10-2013, 05:11 PM
  2. How much bleach for 7000 gallon pool?
    By Budlight592 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-24-2012, 11:43 PM
  3. Bleach Dose amount when filling
    By PaPoolNewB in forum Pool Chemistry for Intex-type Pools
    Last Post: 07-31-2012, 01:10 PM
  4. WalMart ultra bleach is now available in 1 gallon jugs.....
    By aylad in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-06-2012, 01:09 PM
  5. Filling and when to start adding bleach
    By NWMNMom in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-28-2006, 10:29 AM
