Thread: Vogue Trendium 54" Salt water above ground pool ... HELP, NEED SPECIFICATIONS MANUAL
    May 2014
    Louisiana
    Default Vogue Trendium 54" Salt water above ground pool ... HELP, NEED SPECIFICATIONS MANUAL
    We bought a house last year and it came with a pool and we are attempting to ready the thing. It has no manual, the liner is missing, and the hayward pump has corroded away from the stand. The sand filter doesn't have any labels to follow and the gaskets and wall track have been blue threadlockered. Does anyone know the correct liner, and salt info for this to be up and running according to spec?
    Default Re: Vogue Trendium 54" Salt water above ground pool ... HELP, NEED SPECIFICATIONS MAN
    Above-ground pools tend to have fairly meaningless names. And, because of private-labeling, even the brands can be pretty meaningless. But, Google seems to think that this company:
    http://www.piscinesvogue.com/contact.php
    is the one that made your pool. I didn't see any links to manuals, however.
    Equipment is a bit more standard. If you want to post pictures, using links to Photobucket, Flickr, Picasa or what not, that would make it much more likely someone could help.
    May 2014
    Louisiana
    Thank you for your help. I submitted a request on their site for more information. Now for a salt water system... ugh.
  1. Introduction, Specifications and a Question
    By DawizNJ in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-22-2012, 06:03 PM
  2. Above Ground Salt Water
    By BeanoB in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-25-2011, 05:55 PM
  3. Salt water conversion(above ground pool)
    By lndknox in forum Above-Ground Pool Construction & Repair
    Last Post: 06-15-2011, 07:22 AM
  4. Any Vogue Pool Owners?
    By SherrySt in forum Above-Ground Pool Construction & Repair
    Last Post: 06-03-2006, 11:10 PM
