Results 1 to 9 of 9
Thread: Cloudy Water After Green to Clean Treatment
    May 2014
    Riverside County, California
    Default Cloudy Water After Green to Clean Treatment
    Hey everyone i went over to leslies pools last weekend and bought everything i needed to do the green to clean treatment on my 10k gal pool. I did everything by the book and all the algae i had is dead yet my pool is sill cloudy as heck. I used leslies clarifyer and no such luck. Any suggestions. I dont have a test kit for the pool as of yet. I have to wait till my landlord can bring it over.
    Default Re: Cloudy Water After Green to Clean Treatment
    Most of the suggestions we have, won't help you. (Don't use Green to Clean, get a good test kit before starting, etc.) If you've read here much, you'll have probably realized that we don't think highly of "doing everything by the book", unless it's OUR book. (Another pool forum follows pretty much the same rules developed here.)
    But if you've successfully killed all the algae, that is ALL "Green to Clean' is supposed to do; it does NOT remove dead algae from the water. You can remove algae by
    1. Filtering it out, OR
    2. Letting it settle (possibly with the help of floc), and then vacuuming it to waste.
    You can't remover it chemically, at least not with any methods that won't damage your pool.
    Good luck!
    May 2014
    Ok ill have to take a look around for the pool test kit. Im just renting a room and the landlord has alot of his things mixed up in the garage. Once i do find it would you mind if i ran the numbers by you and you can kindly direct me in the right direction?
    May 2014
    Default HELP Totally New to this.
    Hey everyone name is Matt. Just moved into a room in a house that has a 9,1?? gal pool. Since the man of the house passed away i have been asked to keep the pool up and running as best as possible. Well it was completely Cover in algae when i moved in and i finally use the green to clean method of doing it. (BIG MISTAKE I KNOW) So now all the algae is outta the pool by way of using the vaccum, I need to get the cloudiness out of the water. I tried using a clarifier but no help there. So i was told to test my chlorine level well there isnt one. Im sure thats a problem right there. So im at a total lost at what im suppose to do or not suppose to do. Can anyone lend a helping hand????
    Default Re: HELP Totally New to this.
    Matt,
    I merged your other thread with this one. Instead of starting a new thread about basically the same problem, let's keep it all in one place. Thx!
    What kind of test kit are you using? Can you post some current water testing numbers taken with a drops-based kit? Can you list everything you have added to the pool, meaning ingredients and not just product names? Also, what size is the pump and what type and size is the filter?
    May 2014
    my chlorine levels are zero'd out. my ph is 8.2
    Is there any other test or tests i should run?
    Im using a Blue Devil Chlorine/Bromine Deluxe Pool and Spa Test Kit.
    Like i said before im totally New to this thing.
    + Start adding plain 8% store bleach, at the rate of 1/2 gallon per 10,000 gallons of pool water -- added each EVENING.
    + Read http://pool9.net/ma/, then buy a gallon of muriatic acid. Begin dosing at approximately 1/4 gallon per 10,000 gallons of pool water.
    + Tell us who's responsible for the pool: you or the landlord? Who pays for chemicals and maintenance.
    May 2014
    Im Just Responsible for the cleaning and up keeping of the pool. The landlord and her son pay for all the chemicals and supplies.
    OK.
    I was thinking that something like that was going on.
    I'm sorry, but our 'help model' assumes we're talking to someone with the ability to decide, and execute those decisions. We discovered a long time ago, that things broke down if the person we're talking do isn't actually able to do what we suggest . . . because they aren't really the one in charge.
    In truth, your landlord or her son need to be the ones asking questions here. This time of year, we're so far behind it makes no sense for us to spend lots of time with someone we can't really help.
    But you're welcome to read.
    Good luck!
    Best wishes.
  1. Metal Stain Treatment + (Combined) Chorine = Pea Soup Green Pool Water
    By ChuckDavis in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 05-13-2013, 06:08 PM
  2. Replies: 8
    Last Post: 08-04-2012, 11:43 PM
  3. Brown sediment and Green Water after Metal Treatment
    By mariella in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 07-27-2006, 11:46 AM
  4. Water turned green after adding shock treatment
    By NowhereMan in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-11-2006, 12:25 PM
