Thread: Pool cleaning eqpt
    Default Re: Pool cleaning eqpt
    Talk to Polaris customer support; their pressure side cleaners *might* be able to do it, and it would certainly be simpler with one cleaner, than with two.
    If you find out that two are needed, you may want to set up a timer that can switch the booster pump ON/OFF (timer core #1) and operate a powered Jandy valve (timer core #2) to SWITCH between cleaners. I can just imagine the tangles, if you let them both run at the same time!
    . . . membership updated.
    May 2014
    Southwest Desert
    Thanks for the advice PoolDoc. I was hoping that since there are several lap pools out there that someone would have a definitive answer. I have two Hayward Variable pumps and would make the hoses only reach midway in the pool to avoid potential tangling but I thought that in this day and age there would be a more practical solution.
    What you are describing is a very, very small market. The only sort of enterprise that might target that would be garage-shop level.
