Re: OK, need advice on next move.
I merged your new post from today with the thread you had been using yesterday. It is easy to get lost on the forum when you're new, but you'll learn your way around here!
Until you get the dichlor, you'll probably find that you need to add bleach a couple times per day because without any CYA in there, it will quickly be lost to the sun. For reference, in your pool (approximately 11,400 gallons) each quart of 8.25% bleach will add about 1.8ppm of chlorine. Use that as a reference to help you figure out how much bleach to add.
You should also try and drop your pH a little with some muriatic acid but please read the tab in my signature below about using it safely.
