Results 1 to 10 of 28
Thread: Brand new and overwhelmed above ground pool owner...
    Default Re: Brand new and overwhelmed above ground pool owner...
    1. It only takes 2 -3 days to get a nice crop of algae going. On typical AG pools (over-sized pump; undersized filter) it can take weeks and $100's to clean up. Follow the instructions below, if you'd prefer to avoid that.
    2. If it's on, turn your SWCG off (salt water chlorine generator). Don't turn it on, till you've added salt. Read the manual, while your waiting.
    3. Return the monopersulfate if you can. It's essentially useless. It is NOT a sanitizer, and will do NOTHING to kill algae.
    4. Go to Walmart and get a cheap OTO/phenol red testkit, and 8 gallons of PLAIN 8% household bleach.
    4. Add 1 gallon the first EVENING you have the bleach.
    5. Add 1/2 gallon every subsequent evening, AFTER you test pH and chlorine. If your chlorine test result is DARK yellow, skip the bleach dose.
    6. If your pH is below 7.0 or above 8.0, report that result here.
    7. Read about the Super Simple recipe -- it may not be the method you choose to follow, but it will inform you about some options.
    http://pool9.net/ssr/
    8. Let me say it a bit differently than I did in #1 above: it's much, MUCH easier to avoid pool problems, than to fix them!
    9. Pool chemistry is intimidating at first. There's no way to avoid that, that doesn't involve wasting $$'s and time. We can make it much easier - but not completely easy. It will be easy later.
    10. Any pool dealer or contractor that tries to start up your pool with monopersulfate is not to be trusted. They are either ignorant, or malicious.
    11. Order a K2006. You'll need one to take care of your pool: http://pool9.net/test/
    Good luck!
    May 2014
    Thanks!
    Well my wife tossed the bag of monopersulphate in.
    Here are my specs:
    The SWCG has NOT been installed yet.
    Hayward Power-Flo Matrix
    Hayward XStream
    21' Round Resin 52" high
    Am I screwed now that the monopersulphate is in there?
    Do I follow the plan in the post above?
    Thanks in advance!
    Joe
    9k gallon 21' AG pool. PF=13, Hayward Power-Flo Matrix 1.5HP, Hayward XStream CC15093STL, Breeze 320 SWCG, Aquabot Pura 4Xi, Solar-Cell Sunblanket
    A single bag of MPS won't be a problem.
    DO follow the plan outlined above.
    May 2014
    Thanks PoolDoc,
    I went ahead and ordered the K2006 and the K1766 from Amazon.
    I'll be picking up the following tomorrow:
    8 Gallons of Bleach
    4 Boxes of Borax
    Plastic Measuring Cups
    HTH 6 Way Test Kit
    Should I go ahead and buy my salt while I'm there?
    The SWCG will be installed Wednesday. I'll assume I leave it off until you tell me otherwise.
    Thanks,
    Joe
    Salt keeps indefinitely, so if you've got room to store it, by all means go ahead.
    May 2014
    Thanks again. I updated my signature with all of my equipment, at least now I'll know if my money was well spent.
    I'll dump the first gallon of bleach tonight and report back my PH and Chlorine tomorrow morning.
    Again thank you for your time and courtesy,
    Joe
    May 2014
    Chlorine: .5-1
    PH: 7.2
    Thanks,
    Joe
