I assume, since you reported your chlorine in such a wide range (5-10) that you did not use your new kit to get your readings. Continue to follow the SS recipe but using bleach until you get your Dichlor.
Practice with your kit. Run all of the tests except the CYA test. Obviously, you have none in there yet and there is no reason to waste that reagent.
These testing demos may be helpful:
http://pool9.net/tk-guide/
