Thread: First post - Equipment Maintenance
    May 2014
    Manitoba
    Default First post - Equipment Maintenance
    Hello all,
    This is my first post. I just purchased a home with a pool and have been getting advice from my friend who follows the BBB method. So, I'm converting to that.
    Meanwhile, I don't have any maintenance records or information on the pool, other than it was new in 2007. I'm guessing the sand in the filter has never been replaced. Any advice on whether I should tackle this myself or get a pool service company to do it?
    Likewise, is there some maintenance that I should be doing for the pump or gas heater?
    I would sincerely appreciate your advice and look forward to becoming an active member here.
    Default Re: First post - Equipment Maintenance
    Smart decision to follow our BBB method. It is easy, it is cheaper than pool chemicals and it works!
    You should NOT need to change your sand. Sand does not wear out and many of us have sand for a whole lot longer than 7 years.
    I am not the pump or gas heater expert so I'll let someone else address those questions.
    Go ahead and order a Taylor K2006 or 2006C (better buy) test kit. It won't be available locally; you can click on the test kit link in my signature and order one from Amazon. It will make things much easier for you than trying to get by on a cheaper kit.
    Do a lot of reading on the forum, especially the stickied threads at the top of the various subsections of the forum. Also, read over on our sister website www.poolsolutions.com. Lots of good info there as well.
    We are glad to have you join us! Let us know if you have more questions and someone here will try and help!
    . . . membership upgraded.
    Most pump maintenance amounts to (a) installing it correctly, (b) not running it dry, (c) making sure that it can ventilate (move trash and leaves), (d) keeping the basket clear, and (e) winterizing properly.
    Filter maintenance means keeping clean and supplied with media, and winterizing properly. Of course, there's variation between types of filters.
    If you Google for your make and model of pump and filter, odds are you can find the manufacturer's manual online.
    May 2014
    Plano, TX
    Since you are in Canada, you may not be able to order that test kit from Amazon. Check that before you order.
    Enjoy the pool!
    May 2014
    Manitoba
    Thanks all. I'm going to try to order it through Amazon and have it shipped to a border town. It's a couple hours road trip.
    Is that cheaper than ordering through Apollo pool?
  1. Post tetraborate experiment maintenance
    By kelemvor in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 03-09-2012, 02:16 AM
  2. post installation of equipment
    By Michaela521 in forum In-Ground Pool Construction and Repair
    Last Post: 10-10-2006, 03:49 PM
  3. Maintenance Polyquat?
    By csevel in forum Dealing with Algae & Slime
    Last Post: 06-14-2006, 10:56 PM
