Results 1 to 10 of 18
Thread: My pool pump motors hate me
    Straightleg Guest
    Default My pool pump motors hate me
    Bought my pool 10-12 years ago. I installed it. Then put a friends pool in same time. Mine is 33ft, he only had room for a 20ft.
    Bought packages came with the same sand filter and motor size from watsons.
    He is on his second motor.
    I am on my 5th motor. First motor lasted 2-3 months took it back they gave me another. I put all my pump, filter and parts in heated basement over the winter.
    That motor lasted a couple of years then noisy, to noisy to sit next to pool.
    Next motor 2 years, noisy bearing went bad.
    Getting to the point this hayard motor is one season old with my new xtreme cartridge filter. Opening my pool yesterday, Motor is super loud, it is one season old and it was stored in my unheated garage over the winter.
    When I take a motor off, will have to put a new one on while the old one gets rebuilt or i throw the darn thing in the garbage. I have a rebuilt motor on my delta unisaw tablesaw that is 23 years old What is up with these pool filter motors.
    What do I do. My pool pump motors hate me.
    SL
    Default Re: My pool pump motors hate me
    Quote Originally Posted by Straightleg View Post
    Your last sentence made me laugh! I'm sorry I can't help with this one but someone will be able to. Just wanted to say thanks for the chuckle!
    Straightleg Guest
    Your welcome...
    I have tried 220 volt, inground pool pump, 3 different 110 pumps, sand filter, now hayward xstreme 150, with 1.5 hp motor that came with it.
    I have all 1 1/2 lines, maybe 12 ft total, pump is right next to pool. Heavy duty clear plastic lines 3ft from 1 1/2 line to intake and return.
    I need a quite motor, so I can leave my windows open at night.
    I need info before I buy anything else. I think I have around 28,000 gallons of water
    SL
    mas985's Avatar
    Pleasanton, CA
    What pump model do you currently have?
    I think the Matrix came with that filter but I want to make sure. That is normally a fairly reliable pump so there must be something about your installation that is causing issues with the pump. Can you post a picture of your setup? Is there anything unusual in your setup?
    This assumes you actually need to run your pool at night. Given most pools can get away with less than 4 hours of run time per day, you could just choose a run time not at night. But also a two speed would really help the noise factor because you can run on low speed most of the time.
    Mark
    Straightleg Guest
    In the past, I have run 24/7..If I did not then algae would start forming on the bottom. I was not doing the bbb, so hope this makes a difference. Will go out now and take photos.
    I have a very good electrician run my electric to pool for me
    SL
    Straightleg Guest
    Set up and electric
    SL
    mas985's Avatar
    Pleasanton, CA
    Usually algae is more of a chlorine issue than a run time issue. If you were using trichlor (pucks) before and the FC level was too low for the CYA level, which happens a lot with pucks, then sometimes circulation can help a little but you are much better off getting the FC/CYA level correct than trying to solve the issue with pump run time.
    Mark
    Straightleg Guest
    Well on a new system now...Be nice to turn it off 12 hours or so a day. What do you think of my set up. Why am I going through so many motors. Does water get into those bearing that easy, or what ever is making me replace so often.
    Gerry
    Jun 2013
    Central Florida
    My pump does not need the attention you describe. The guy I use to rebuild when I need it pointed out some rust on the bottom side of the motor housing due to a small leak. He said the rust deforms the housing and pushes the motor armature/ bearing plate out of line. It doesn't take much rust to do it because the tolerances are pretty close. Does your motor get wet? Can you see any rust?
    mas985's Avatar
    Pleasanton, CA
    Most pumps protect the bearings from moisture but that one looks like it might allow some water to get into the bearing area which really shortens the life of a pump. The matrix is a bit more shielded.
    Mark
  1. Need Help Deciding: AO Smith Motor for Inground Pool, or Emerson US Motors?
    By hotajax in forum Pool Equipment & Operations
    Last Post: 05-30-2013, 01:35 PM
  2. Pump Motors
    By Pigseye in forum Pool Equipment & Operations
    Last Post: 07-02-2012, 04:47 PM
  3. Advice on Pump Motors
    By poolboy69 in forum Pool Equipment & Operations
    Last Post: 07-13-2008, 04:56 PM
  4. Swapping pump motors
    By lmnharris in forum Pool Equipment & Operations
    Last Post: 06-14-2006, 09:42 PM
  5. Controlling 2-speed pump motors with Aqualogic or Autopilot?
    By Beautye350 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 04-18-2006, 07:05 PM
