Results 1 to 9 of 9
Thread: 18 x 36 filled with algae
    May 2014
    South Carolina
    Default Re: trying to get pool right
    I used to 6-1 kit you recommended. What about the alkalinity?
    Is your pool still green? Worry about getting it clear and then you can tweak your alk.
    May 2014
    South Carolina
    Low end is good. Deep end still murky. Going to floc it one more time. Last text it dropped a lot of algae
    May 2014
    South Carolina
    Think I have mustard algae. water is clear until I sweep affected areas - then turns into a brown cloud. What can I do? Used a clarifier last night and problem seems worse today. Waiting on my Taylo test kit to come. Afraid to go to pool store as I am sure they dont give me accurate test results for water sample
    18 x 36 vinyl IG pool; Tagelus sand filter; 3/4HP pump; booster for Pentair cleaner; SWCG, Taylor Test Kit
    May 2013
    Northwest Indiana
    First of all, I would suggest no more pool store chemicals (floc, clarifier, etc.). Next get familiar with the "Best Guess" Chart in Watermom's signature. At 60ppm cya, 10 ppm of fc is too low to deal with algae. You need to be at +Shock levels and keep it there until 1) water is clear, 2) cc is 0.5 or less, and 3) you lose no more than 1ppm of fc between sundown and sunrise.
    -Eric B. 16x32 rect 14,364 gal AG (Intex Ultra Frame); 14 in sand filter; 1 HP 2800 GPH pump; 8 hrs; Taylor K-2006c, utility water, debris cover
    @Best Guess chart http://pool9.net/cl-cya @K2006 http://pool9.net/testkits
