Re: How to connect 16 solar panels for best performance
Thanks for all the input.
So 3 groups in parallel makes no difference because running all panels in one group is also parallel and shouldn't be a problem when the manifolds are 40mm (only slightly smaller than my 50mm piping)?
Also, 3 groups requires al lot more piping and thus possible leaks. So is it really worth having 3 parallel groups compared to one parallel group?
