I need to edit that page -- but here are the two lines that describe what you do AFTER start-up:+ At the first sign or algae, or slippery sides of the pool (pre-algae) add 4 doses of bleach in the evening, IN ADDITION to your regular dichlor dose.
+ Test the chlorine and pH each morning; if chlorine is below 2 ppm, add 1/2 dose of dichlor; if the pH is below 7.0, add 4 doses of borax. If the pH is above 8.0, skip borax additions till it goes below 7.4.
