Results 1 to 10 of 40
Thread: Newbie 14' round intex
    May 2014
    Plano, TX
    Default Re: Newbie 14' round intex
    http://www.homedepot.com/p/SAVOGRAN-...0622/202935862
    or equivalent is what you want. Real Trisodium Phosphate. NOT "safe" or "phosphate-free" or "TSP Substitute".
    May 2014
    NY
    Cool, thanks!
    May 2014
    NY
    I got the genuine Fibur cartridges from Amazon. I'm not sure if it was Filters Now because it's showing temporarily out of stock. Anywho, here's the link I ordered from. Hope that helps, if not let me know and I'll dig through the receipts.
    http://www.amazon.com/gp/aw/d/B007F8...=ATVPDKIKX0DER
    That helps; no need to dig through.
    Thanks!
    May 2014
    NY
    Another quick question. ..... my cya was 100+ and water looked a little cloudy. From what I understand those cya levels don't allow the chlorine to do its job effectively so I'm trying to stay ahead of the curve so to speak and prevent an algea outbreak. I believe i made a mistake using Dichlor to maintain the chlorine levels instead of bleach. I didn't use Dichlor all the time to bring up the chlorine levels but apparently I did use it too much. So I drained 3/4 of the pool and am going to stop adding Dichlor when I get to about 40 - 50 ppm and then switch over to bleach. I know if my cya drops I need to dose with Dichlor but i wasn't clear on what the ideal chlorine level should be. I just want to make sure I'm not missing anything else and I get it right. Thanks in advance.
    You need to check our "Best Guess Table" for the CYA/FC relationship. Normally, when CYA is 100, the maintenance level of FC is 8-15ppm, and, if I remember correctly, shocking level is 25ppm (may be 30).
    if CYA is 50, again, from memory, maintenance FC is 3-6ppm and shock level is 15....but check the table.
    May 2014
    NY
    Hi Folks,
    I had a quick question regarding fc levels. Unfortunately or fortunately for me, my wife let me sleep late not realizing I needed to do water tests. Anyhow, I just tested my water at 1230pm my readings are
    FC 14
    CYA 55
    According to the cya chart, 20 would be shock level and 7 the ideal FC. So my question is..... can I put my 5yo in the pool with those numbers? Btw, my FC is high because I saw algae on the bottom so I dosed with bleach x4 over the last two nights.
    Many Thanks!
  1. newbie 21' round AG with hazy water.
    By jeffstang in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-13-2013, 11:43 AM
  2. intex 22' x 52' round
    By eagles in forum Pool Chemistry for Intex-type Pools
    Last Post: 07-04-2012, 07:39 PM
  3. Anyone buy the new 27' round Intex yet?
    By ThaSatelliteGuy in forum Intex-type Pool Setup & Operations
    Last Post: 05-13-2012, 02:48 PM
  4. Newbie needs help with 33 round rail/wall coming apart
    By KMKjr in forum Above-Ground Pool Construction & Repair
    Last Post: 08-11-2011, 12:04 AM
  5. Above ground Intex 15 ft round pool - take down or winterize?
    By blessedbeingmom in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-27-2010, 07:14 PM
