Results 1 to 10 of 40
Thread: Newbie 14' round intex
    May 2014
    NY
    Default Re: Newbie 14' round intex
    I got the genuine Fibur cartridges from Amazon. I'm not sure if it was Filters Now because it's showing temporarily out of stock. Anywho, here's the link I ordered from. Hope that helps, if not let me know and I'll dig through the receipts.
    http://www.amazon.com/gp/aw/d/B007F8...=ATVPDKIKX0DER
    That helps; no need to dig through.
    Thanks!
    May 2014
    NY
    Another quick question. ..... my cya was 100+ and water looked a little cloudy. From what I understand those cya levels don't allow the chlorine to do its job effectively so I'm trying to stay ahead of the curve so to speak and prevent an algea outbreak. I believe i made a mistake using Dichlor to maintain the chlorine levels instead of bleach. I didn't use Dichlor all the time to bring up the chlorine levels but apparently I did use it too much. So I drained 3/4 of the pool and am going to stop adding Dichlor when I get to about 40 - 50 ppm and then switch over to bleach. I know if my cya drops I need to dose with Dichlor but i wasn't clear on what the ideal chlorine level should be. I just want to make sure I'm not missing anything else and I get it right. Thanks in advance.
    You need to check our "Best Guess Table" for the CYA/FC relationship. Normally, when CYA is 100, the maintenance level of FC is 8-15ppm, and, if I remember correctly, shocking level is 25ppm (may be 30).
    if CYA is 50, again, from memory, maintenance FC is 3-6ppm and shock level is 15....but check the table.
    May 2014
    NY
    Ok, I'll check that out. Thanks for the quick response.
    May 2014
    NY
    Hi Folks,
    I had a quick question regarding fc levels. Unfortunately or fortunately for me, my wife let me sleep late not realizing I needed to do water tests. Anyhow, I just tested my water at 1230pm my readings are
    FC 14
    CYA 55
    According to the cya chart, 20 would be shock level and 7 the ideal FC. So my question is..... can I put my 5yo in the pool with those numbers? Btw, my FC is high because I saw algae on the bottom so I dosed with bleach x4 over the last two nights.
    Many Thanks!
    Effectively removing algae requires not only higher chlorine, but also physical disruption of the algae with brushing.
