Jake,
Total Hardness is probably referring to Calcium Levels which are not related to TDS. Disregard all of them for your pool....not important.
If you water is unsatisfactory, bring your Cl level up to around 15ppm and KEEP IT THERE 'til you water looks the way you want. KEEP IT THERE by testing for FC as often as you can (dusk and late night are the best) and adding enough bleach to bring it right back up to 15ppm. Run your pump 24/7 during this process.
Based on your description, your water will clear up pretty quickly....day or two usually.....but only if you"KEEP IT THERE"
Skip the pools store stuff....you don't need it
"KEEP IT THERE"
