Thread: Pool chemicals and running the pump
    Jun 2013
    Default Pool chemicals and running the pump
    Hello all,
    I have a general question about putting chemicals in the pool and then running the pump. Does running the pump have any effect on the chemicals I put in? In other words, if I put dichlor and borax into the pool and then run the pump, will it filter out the chemicals or help distribute them better?
    Thanks!
    Jun 2013
    Default Re: Pool chemicals and running the pump
    thank you!
    16' x 4' Intex round pool, 6,000 gallons
    You're welcome.
  1. pump running 24/7 or what?
    By airraid1999 in forum Pool Equipment & Operations
    Last Post: 07-09-2011, 06:39 PM
  2. Pool pump needs to run when cleaner is running ???
    By oroepke1 in forum Pool Cleaning: Manual or Automatic
    Last Post: 10-24-2010, 11:14 PM
  3. Running pump at night?
    By Cold Drink in forum Pool Equipment & Operations
    Last Post: 08-07-2007, 07:59 PM
  4. running pump
    By nicker in forum Above-Ground Pool Construction & Repair
    Last Post: 07-28-2006, 07:57 PM
  5. going without running pump while on vacation
    By gonefishin in forum Pool Equipment & Operations
    Last Post: 06-09-2006, 10:55 AM
