Thread: Tips on adding salt
    May 2014
    Default Tips on adding salt
    I had my pool resurfaced and I've been experimenting with ways to mix in salt to my fresh water. Without a doubt, the best way to force the salt to dissolve quickly was to create up/down currents so that the high salt concentration on the bottom of the pool mixed with low salt content water on the upper water volume. You can watch this in action by the following steps:
    1. Broadcast salt along the pool edges as evenly as you can.
    2. Go to any locations where the salt has visibly accumulated into a large undissolved patch on the pool bottom.
    3. Agitate the water upward and downward over the salt patch using a pole with a blunt attachment (such as a large brush or net). Create as much water movement up and down as possible and make sure you are driving the top water layer down to the bottom.
    My pool is about 70F and it takes about 5 up/down plunges with a large brush to dissolve any salt patches (less than 15 seconds). On the other hand, when I simply try to brush the salt horizontally it just spreads around but remains relatively undissolved.
    Hope this helps others save some time and minimize damage to your pool surface and equipment.
    Default Re: Tips on adding salt
    Quote Originally Posted by Carlsbad View Post
    Uh. Why?
    Unless you're using low grades of salt that contain iron and are liable to stain . . . it seems pretty easy to just dump it in and walk away.
  1. Adding salt for the season
    By jilted in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 02-25-2012, 05:53 PM
  2. 26k gal AGP adding salt
    By madwil in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-04-2011, 06:00 PM
  3. new ? on adding salt to non-SWG AG pool
    By GraceByDesign in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-31-2006, 09:08 PM
  4. Adding salt to inground pool
    By ksturge in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-14-2006, 07:36 PM
  5. Adding salt?
    By rustypixel in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-01-2006, 08:40 AM
