I am a first time pool owner.
Got the pool set up over the weekend and got all the levels Correct . I added algae control last night. I haven't cut the pump off since I set it up in fear that it would turn green. It has been raining here most of the week so I put the cover on. I have been carefully siphoning rain water off the top. So today I looked at the jet to feel it before cleaning the filter and I have bubbles coming out of the jet. The intex site said check fittings for good o rings and relube. I did. And the same thing....... bubbles.......As I further read to check the impeller in the pump to make sure it was free of obstructions. Took the pump off broke it down and nothing catching the impeller. Put it back together and it wouldn't do anything... Tore it down again and untorked the screws a bit and reassembled the motor. More bubbles than when I*started. Apparently I made them too loose because the third time I torked them just a bit and at least made it bubble the same as before I did anything.
Do I have a leak in the pump or would the algae control make the bubbles? I plan on calling intex tomorrow about the pump. It doesn't feel like its blowing as hard as it did at first and I have been cleaning the filter twice a day.
Any help would be appreciated. Tks
