Ok, all of the suggestions have been enacted. I kept the pool at shock level one more night, then changed the sand, then added cya. So what should I do for maintenance? FC levels should stay around 3ppm after the CYA reaches 30ppm right? Is that all I need to check? And of course remove leaves and debris regularly...is there a good maintenance thread?
