Thread: Colorlogic lighting
    May 2014
    Wisconsin
    Default Colorlogic lighting
    My lights are not in sync. I have two Colorlogic lights that function, but not in sync.
    Any suggestions to reset?
    Largo, Florida
    Default Re: Colorlogic lighting
    I believe you will need the "Hayward ColorLogic Network Module" if they are Colorlogic 4.0 lights.
    You can contact Hayward directly to find out if there is a way to do it without the module (or if they are older lights):
    Hayward Pool Products
    (908) 355-7995 (U.S.) Mon-Fri, 8 AM – 5 PM
    One Hayward Industrial Drive
    Clemmons, NC 27102
    Another thought, if you don't have a Pro Logic controller and/or don't want to spend the bucks on the network module. AND you are competent with wiring, you can probably get things pretty close by changing your switch to an DPDT switch. Levitton (the Lowes brand) makes such switches in a few colors.
    . . . membership updated.
    Thanks, Kelemvor!
  1. Light niche and ColorLogic LED
    By gordonhyde in forum In-Ground Pool Construction and Repair
    Last Post: 09-30-2006, 01:50 PM
  2. ColorLogic Lights - Pics
    By tagprod in forum Pool Equipment & Operations
    Last Post: 08-15-2006, 04:34 PM
  3. SaVi LED vs. ColorLogic
    By scott747 in forum Pool Equipment & Operations
    Last Post: 07-16-2006, 07:13 PM
  4. ColorLogic lights
    By theplant in forum Pool Equipment & Operations
    Last Post: 06-16-2006, 05:10 PM
