Thread: Leak in new Intex pool - What to do?
    Jun 2012
    Minnesota
    Angry Leak in new Intex pool - What to do?
    I have upgraded us to an Intex metal frame pool - 15' by 48". I was setting it up today for the first time and, upon putting water in, discovered a leaky seam at the bottom where two side panels meet. It's within an inch of where the two panels also meet the bottom panel but, as near as I can tell, it's the seam between the two walls that is leaking.
    It took me the better part of a day to put this thing together and I'm loath to have to tear it down and exchange it for a new one. Not to mention the time it will probably take to deal with Intex on this.
    Any advice? Though I don't want to deal with a replacement, my gut is telling me that trying to fix this well end up a losing battle that causes me to hate my new pool in the coming years. I thought about trying silicon or a patch but I'm not sure I can fix a leaky seam. I'll attach a picture of the leak.
    Thanks!
    Donovan
    15' round 4K gal Intex AG vinyl pool; Kem-Tek granulated dichlor; Unicel Type A cartridge filter; Intex Krystal Clear, Model 637R, pump; 12hrs; Taylor K-2600 test kit; utility water; PF:30
    May 2014
    Plano, TX
    Default Re: Leak in new Intex pool - What to do?
    Since it's a seam leak, I'd question the integrity of EVERY seam in that piece. The operator or a poorly maintained/adjusted machine could be the cause of the issue and might extend to ALL seams, so I'd suggest replacement. You don't want to get it 3/4 full and have the side seam blow out.
    Where and when did you purchase the pool? If you put the purchase on a credit card, you my have some leverage through the CC company. Most big-boxes have a 30 day return/exchange policy.
    Jun 2012
    Minnesota
    Thanks, Watermom! Intex requires a receipt for replacement. We bought it a couple of months ago on sale so finding said receipt poses a challenge. But if I can find it, I intend to get the liner replaced.
    In the meantime I went ahead and patched it with the stuff that came with the pool. I figured it couldn't hurt; the person I talked to at Intex didn't seem to care and indicated that the only needed a few pieces of the liner if I decide to try replacing it.
    The wasted time, if I do get it replaced, does grate on my nerves.
    Jun 2012
    Minnesota
    Good thought, Pappy. Didn't think of that. As outlined above, I do intend to have it replaced if I can find the blasted receipt. I'm also trying to figure out which credit card we used so I can find the statement. Since it was a couple of months ago, I'm having some trouble remembering how we paid for it.
    Not that my home is chaotic or anything...
    Anyway, thanks for the advice!
  1. Intex Sand filter suction air leak or...???
    By BlueCorn in forum Intex-type Pool Setup & Operations
    Last Post: 06-06-2013, 10:03 PM
  2. Pool Leak
    By ellry99 in forum Pool Equipment & Operations
    Last Post: 06-12-2006, 02:17 PM
  3. Pool Leak?
    By PoolNewb in forum In-Ground Pool Construction and Repair
    Last Post: 05-31-2006, 01:14 PM
  4. pool leak?
    By packerfan in forum In-Ground Pool Construction and Repair
    Last Post: 05-27-2006, 10:31 AM
  5. New Pool with a leak.
    By Guido in forum In-Ground Pool Construction and Repair
    Last Post: 04-03-2006, 10:52 AM
