Look in your toilet tank - is IT stained? What color?
(Iron can be present, but not show up on tests, because once it hits the pool, it becomes a stain so quickly. And once it's a stain, it's no longer in the water!)
PoolDoc / Ben
No metals in your water!!
I should qualify that, after looking more closely. I should have said: "Very low levels of iron in your water!"
Bottom line though, is still the result of testing Vitamin C and Iron Out on stained areas.
I'm not sure if it's a typo, but their current price for Iron Out is very cheap:
Super Iron Out IO30N Rust Stain Remover
Ascorbic Acid Powder
So Vitamin C is used to put the iron back into the pool? Or does Iron Out and the Vit C do different things. I ask because I have a 13.5k pool and wondering if I need to go ahead and get 2 lbs of Vit C or just a small bottle to test first?
I know I am not at that stage yet, as I still need to verify it will work with testing a spot. With that being said as you know I have a SWCG and IntelliPH. I notice in your process you say use bleach to bring up chlorine. Do you think I can get the same affect with an SWCG? plus once chlorine comes back you say to use borax to slowly bring up PH, I assume my intelliPH will allow me to do that no problem. Is there any affect to my salt PPM in the pool while doing this treatment (i.e. will it reduce salt levels).
I am just trying to make sure I fully understand how to bring the system back up after treating.
13.5k gal IG pool with SWCG and intelliPH
Just use them both on spots, and see if the spots are lifted.
Let's worry about full understanding, later. If neither lift the spots, there's not much here to understand.
BOTTOM LINE: We do NOT have a reliable procedure for removing stains and then removing the metals from the pool. We've had some success with working out methods by which people can manage the stains and metal, but we are a long way from a reliable complete method.
