Help
Remember Me?
Forum
FAQ
Calendar
Forum Actions
Mark Forums Read
Quick Links
View Forum Leaders
What's New?
Advanced Search
Forum
Help with starting new pool
FAQ
register
Results 1 to 10 of 27
Thread:
Thread Tools
Show Printable Version
Email this Page…
Subscribe to this Thread…
Display
Switch to Linear Mode
Switch to Hybrid Mode
Threaded Mode
Threaded View
06-02-2014
12:14 PM
#11
PoolDoc
View Profile
View Forum Posts
Administrator
Quark Inspector
Re: Help with starting new pool
You can scatter it in the pool -- but unless your pH is low, don't do so!
Quick Navigation
Top
Site Areas
Settings
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
Forums
Ben's Corner
Forum Q & A
-- Subscriber Posts --
Dealing with Algae & Slime
DPD-FAS based testing
Pool Equipment & Operations
Pool Electronics
Odds-n-Ends (P)
Photo Gallery
Clearance
--cleanup--
The China Shop
General Interest
Practice Forum
PoolSolution Archive
The Hall of Shame
BB Method (Instead of BBB)
PH and Total Alkalinity
Newbie here, starting up FG pool
By tjbates in forum Pool Startup, Shutdown, & Winter Operation
2
Last Post:
06-01-2014,
09:45 AM
starting old pool
By csc138 in forum Pool Startup, Shutdown, & Winter Operation
2
Last Post:
06-26-2012,
03:44 PM
New Pool & Starting From Scratch!
By tnt69 in forum Testing and Adjusting Pool Water Chemistry
15
Last Post:
02-04-2012,
04:59 PM
Starting the pool process
By hop6868 in forum In-Ground Pool Construction and Repair
3
Last Post:
06-30-2011,
02:45 PM
Digg
del.icio.us
StumbleUpon
Google
You
may not
post new threads
You
may not
post replies
You
may not
post attachments
You
may not
edit your posts
BB code
is
On
Smilies
are
On
[IMG]
code is
On
HTML code is
Off
