Results 1 to 10 of 21
Thread: Pool Pilot Digital 220 unit - Warning Low Amps - Cell? and Bad Temp Sense
    Default Re: Pool Pilot Digital 220 unit - Warning Low Amps - Cell? and Bad Temp Sense
    1. Purchase the largest cell that will fit with your system -- a 10,000 hour unit will last 2x as long (in years) if it's used 1/2 as much.
    2. Never, ever use BOOST. Use a gallon or two of bleach, instead.
    3. Only use your SWCG for NORMAL pool operation -- not for start-up, not for algae, etc. If something's wrong, understand it and fix it manually.
    AutoPilot is by no means the worst, but like most 'new and improved' or 'digital' pool equipment, it is often oversold as a complete solution, when in reality it is just a tool with limitations like every other tool. Quite a few people here think the AutoPilot is the best SWCG, but it's still just an SWCG, with all the limitation inherent in the technology.
    What SWCG's do well is consistently chlorinate pools that are experiencing normal loads. What they don't do so well, is everything else.
    May 2012
    Miami, FL
    my Autopilot cells have lasted around 4-5 years. I use the SC-36
    Jun 2014
    Tennessee
    Thanks for that info. From what I am reading it appears I have been using my system incorrectly and will be making some changes based on above feedback.
    28k gal 20'x40' grecian-shaped vinyl IG pool, 4 returns, main drain & skimmer, Waterway 22" sand filter (new this year - replaced DE filter)
    Ft Lauderdale, Fl
    Sorry to jump in so late, but the information provided in the Original post indicates a warn out cell. Normally the display will show either CHECK/CLEAN CELL or LOW AMPS/CELL?
    However, the high volts and lower amps is indicative of a depleted cell, low salt (and the displayed salt needs to be calibrated), or operation during cold water conditions with low salt levels. I would recommended having your water tested to verify the salinity first.
    If you remove the cell, inspect for any scale formation on the blades. While you have it out, do the outer blades appear to be worn down along the leading edge of the blades? This is a sign of cell depletion.
    Sean Assam
    Thanks, Sean.
    Jun 2014
    Tennessee
    New information, I replaced the tri-sensor and the cell but now have a different message.
    I went with the RC-52 (SC-60) which is the largest my unit will accept. Purchased from saltpoolguys.com.
    The tri-sensor was bad and the new one is reporting a temp of 82 degrees which is what the thermometer in the pool is reading.
    Salt is reported at 3300ppm which is what the old sensor reported and the same as the pool store measured.
    I set the control unit back to power level 1 and changed the cell type to SC-60.
    I still have a flashing red light on the control unit and the message now reads "Warning check/clean cell?"
    The cell is clean and i dont see anything on any of the blades, all 15 are the same length, Some appear to be newer than others so not sure if the cell may be bad?
    when testing the unit I have 17 volts and 2.9 Amps reported on the display.
    When i turn the unit on initially, once it runs throught its tests, the purifier states 60% but within about 5 seconds that changes to 48%.
    The unit is on and states purifier on 48%
    Any thoughts on what could be causing the check/clean cell message?
    BigDave's Avatar
    I noticed on the first post in this thread that a CYA of 0 is reported. Is that accurate? My understanding is that most SWCG manufacturers recommend a CYA level around 60. I would assume that a SWCG would have a hard time keeping up with the chlorine lost to sunlight.
    Jun 2014
    Tennessee
    I connected with Josh from the saltpoolguys.com site, where I purchased the new cell and tri sensor, concerning the new message I am getting.
    After some additional troubleshooting and sharing some pictures of my controller, it appears I have a bad board, specifically 4 of the 6 capacitors are shot and it appears one of the computer chips may have overheated as well.
    The board alone is $400+ and the whole controller unit is 600+ and comes with a new cell cable and a two year warranty so I elected to do the whole unit. Awaiting arrival of the unit, should be here Monday, Tuesday at the latest.
    At that point I will essentially have a new system and just need to get it back operational. Now if I can just keep the pool stable until I can get this installed the grandbaby can get back in the swim mode.
