Thread: Chemical levels???
    mommak is offline Registered+ Thread Analyst mommak 0
    May 2014
    Michigan
    Question Chemical levels???
    Okay, our pooled filled in less than 12 hours. We used 2 hoses, and it filled quickly. I am waiting on our k2006 test kit from Amazon. I have a cheaper HTH OTO 3 Way Test Kit that I bought from Wal-mart. I also have the dip sticks, so I checked and my pH was low, so I added the borax, but when I checked the dip sticks, it looks like the cya is low and same with the alkaline.
    The water is not cloudy or changed colors, thank goodness. Do I wait until tomorrow until my good test kit comes before I add anything else to our pool? It is an Intex round above ground 18' by 48".
    May 2014
    Plano, TX
    Default Re: Chemical levels???
    http://www.poolforum.com/pf2/showthr...p-routine-care.
    Read this. It will make your life easier.
    Actually, following the Super Simple Startup Recipe that Pappy linked above would be a good idea since it is a freshly filled pool. No need to check CYA yet; your pool does not have any in it. CYA is not present in tap water. It is added directly or via trichlor tabs or dichlor powder. If you follow the SS Recipe, it will show you how to get your pool going including introducing needed CYA with dichlor. Once your CYA is about 50ppm, you'll want to switch to just using bleach.
    For today, get some bleach in there. You don't want a freshly filled pool to turn green and you wouldn't believe how fast it can happen! I estimate your volume to be around 7000 gallons. Each quart of 8.25% bleach will add about 3ppm of chlorine to your pool. With no CYA, it will disappear fast -- lost to the sun. So, you'll probably have to add it a couple times per day for the first few days.
    May 2014
    Michigan
    I printed out that plan, and following those steps. I am excited for having such a much simpler way to maintain the chemicals in our pool.
    Yes, simple is definitely good!
  1. How to add or adjust chemical levels
    By justlane4 in forum Dealing with Algae & Slime
    Last Post: 06-26-2012, 11:21 PM
  2. Chemical Help
    By mreesept in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-20-2012, 01:58 PM
  3. chemical levels seem ok?
    By GerriLeAnne in forum DPD-FAS based testing
    Last Post: 07-24-2010, 03:12 PM
  4. Need targets for chemical levels
    By joanie109 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-16-2009, 01:32 AM
  5. Chemical Age
    By mohawk in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-19-2008, 09:02 PM
