Results 1 to 9 of 9
Thread: New Intex pool owner from Michigan
    Jun 2014
    Michigan
    Default New Intex pool owner from Michigan
    Hello I'm a new owner of a 15x42 intex pool and just looking for info on set up and up keep.
    It has the filter that came with pool kit.
    Jun 2014
    Michigan
    Default Re: Hello new pool owner from Michigan
    Not at this time. I just wanted to get my fourm member ship rolling so when I do have questions I will be good to go.
    Ok. Well, we'll be here if you need us!
    Jun 2014
    Michigan
    How much 8.25% bleach do I add at fill up? And how much stabilizer?
    Without knowing anything about your pool, it is impossible to give advice. I assume it may be an Intex or an above ground? If so, using our Super Simple startup guide would probably be the best way to go. You can read about it here: http://pool9.net/ssr/
    (Until your registration is completed, you won't be able to see the rest of the forum while you are logged in. So, copy that link above and paste it in a browser window after you log out.
    Hope this helps!
    Jun 2014
    Michigan
    Its a round 15x42 intex above ground pool. Filled it up and tested my ph and it 7.2.
    Did you look at the link I posted above? Are you going to use that startup recipe? That would be the easiest way to start your pool.
    Your volume is about 4200 gallons. In this size pool, each cup of 8.25% bleach will add about 1.2ppm of chlorine. Until you can get some dichlor, you'll need to add some bleach a couple of times per day to keep your pool from turning green. More info in the page I linked above.
  1. New Owner of a Large AG Pool in Michigan
    By Josh61513 in forum Pool Equipment & Operations
    Last Post: 06-17-2013, 02:49 PM
  2. New Intex Pool owner...
    By mommabeans in forum General Interest
    Last Post: 06-07-2013, 03:45 PM
  3. New Intex Pool owner...
    By mommabeans in forum --cleanup--
  4. New Intex Pool Owner and on a well.
    By virtualmech in forum Pool Chemistry for Intex-type Pools
    Last Post: 07-18-2012, 11:30 PM
  5. New Intex Pool owner
    By tom79904 in forum Intex-type Pool Setup & Operations
    Last Post: 06-28-2012, 12:45 PM
