Don't bother running the CYA test until you have been using dichlor for about a week to 10 days. Before then, you won't have enough in there yet that can even register on the test so you'll just be wasting your testing reagent.
Just keep following the SS recipe. You want the daily doses of dichlor until your CYA is between 40-50. Then you'll want to stop using it and switch to just using bleach. You will never get to the "just one bag of dichlor per week." Long term use of dichlor will cause your CYA to get too high.
The Taylor kit can test chlorine levels past 5ppm, the 6-way kit can't. If you only have the 6-way, it is imperative that you do not let your CYA get too high nor get any algae. Both of those things call for high chlorine levels and you won't be able to test.
Another option you have since you have the 6-Way kit is to just buy the FAS-DPD add-on kit. That will give you the test you will be missing in your kit. Click on the test kit link in my signature and you'll find it. It is the Taylor K1515.
