Yes, keep using dichlor until your CYA is around 50ppm.
Also, remember that since your OTO tester can only read chlorine readings to 5ppm, a reading of 5 means 5 or higher. I linked this above but will do so again -- the chart that helps you interpret higher than 5ppm on an OTO. http://pool9.net/oto-chart/
