Results 1 to 8 of 8
Thread: What do I do first??
    May 2014
    Plano, TX
    Default Re: What do I do first??
    That is correct, but it's a vinyl pool, so TA is not a concern unless pH varies greatly.
    May 2011
    Arkansas
    Thank you! I'll start with bleach and borax then! It's slowly coming back to me.
    Old pool/ new owner =)
    32,600 gallon chlorine, inground, vinyl lined pool with deep end.
    Pump: Haywood 1.5 hp
    Filter: 300# sand filter.
    May 2011
    Arkansas
    OK, I added 3 lbs. of shock (I checked CYA with a test strip and it was 20ish), left and went to walmart. When I came back and hour and a half later, it turned a clear green in the deep end???
    I thought you were going to use bleach. (?) What kind of shock did you add? Please list its ingredients. In fact, please list everything you have used in the pool so far meaning ingredients.
    Do you fill from a well?
