Re: too much chlorine trying to slam to fight algae
Ok...I just tested everything again. I know some of these will change when the chlorine comes down.
Thenwater is a little cloudy but much better than this am. Not crystal clear yet. All debri is gone but still a little dirty. I plan to vacuum tomorrow and clean the filter too since the pressure has climbed a bit.
Chlorine....26.5
PH 7.5
TA 100
CYA 60
CH 110
Salt 2200
I dont know the temp of the water
Should I add more chlorine and then test in the am for loss? Should my target be 35 or 25?
40K gal vinyl FOXX pool; Intellichlor IC60 SWCG; Hayward EcoStar multi speed pump that runs 2925 rpm 8am to 1pm, then 2900 rpm 4pm to 8pm then 2800rpm from 8pm to 11pm.; Hayward Swimclear cartridge filter; Pentair Easy Touch panel with remote.
