I'll let someone else address pool setup questions.
But, I will tell you that as far as cheap/diy heating options, you might consider a solar panel. Having a solar panel makes a huge difference in the water temperature, especially if you combine that with the use of a solar cover on the pool and neither one of those items is very expensive.
By the way, why don't you go ahead and order a good test kit so you'll have it ready to use right from the get-go. The one we recommend is the Taylor K2006 or 2006C (better buy). It isn't available locally, but you can get it through our link that takes you to Amazon:
http://pool9.net/tk/
Another couple of things for you to read include our Super Simple Start-Up Recipe which makes it so easy to get the initial pool chemistry right. Read more about it here: http://pool9.net/ssr/
Lastly, be sure you visit our sister website www.poolsolutions.com. Lots of good info there as well!
(Until your registration is complete, you won't be able to see the rest of the forum or follow these links while you are still logged in. So, copy the links and paste them in a browser window after you log out.
Welcome to the Pool Forum!
