Results 11 to 20 of 23
Thread: Converting Baquacil to Chlorine
    McDonough, Georgia
    Default Re: Converting Baquacil to Chlorine
    Just curious....is it to my advantage to add a chlorine tab to the skimmer basket to help maintain the chlorine level during conversion?
    McDonough, Georgia
    OK...thanks! I think I'm close to turning the corner on the Baquacil battle. Although the water is still cloudy and slightly dull rust in color...it no longer changes color when bleach is added. It also seems to be holding FC level better since the mid-day dose.
    It would be nice to have a clear pool over the weekend.
    McDonough, Georgia
    Just curious, again! Right now my water color and clarity resembles an amusement part water ride. When it begins to clear, is it a slow process or an "overnight" type process? I'm into day 3 of the conversion. I'm trying to keep the chlorine level and FC level around 15 ppm. But it can change quickly when it changes.
  6. #16
    Oklahoma city, Oklahoma, USA.
    Just keep the clorine levels up till you water clears and you will be happy with your desicion ti convert. I had the same problems with baquacil. When I converted I did not have a good kit and it took longer than it should have but it was worth it. I got the kit (ps223) and a lot of help form people here and I have a great pool with little to no problems for 3 years now.
    Kurt Bourn
    24' round 12,000 gal
    Oklahoma City
  7. #17
    Default well, did your pool clear up quickly?
    tgilbert,
    I've read your thread and wondered if you got the results you wanted.
    --Deborah
  8. #18
    McDonough, Georgia
    Yes I did. I'm just getting around to posting this reply...but my conversion from Baquacil to Chlorine completed in 7 days with the result being a crystal clear pool. I probably could have done it quicker but I didn't want to push it. I added 2 gal. of bleach - 3 times a day for 7 days and the pool was clear. I have since washed the filter and replaced the sand. The pool is now in maintenance mode at a fraction of the cost of Baquasil.
  9. #19
    Default Fabulous!
    Glad to hear it. --Deborah
  10. #20
    I too am tired of the cost and battle of a Baquacil pool.We are wanting to convert and I have read these posts but am still kinda lost.Our water level is low and we are trying to decide to change or not.If we do not of course we will have to add water then remove the chlorine(pain in the butt).The Baquacil levels are extremely low so I really don't know where to start.Do I need to get a shock that goes with the chlorine stuff or just use bleach? I am sorry that I am so lost but I need your help.Hope I didn't make this too confusing .Thank you
  1. Converting from Baquacil to Bleach!
    By obelcher in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 06-22-2013, 11:35 PM
  2. Best Thread for converting Baquacil to chlorine
    By relem in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 08-10-2011, 11:51 PM
  3. Converting from Baquacil to Chlorine
    By Linda Fenn in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 08-18-2006, 06:07 PM
  4. Converting from Baquacil to Chlorine
    By tammydiaz in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 07-05-2006, 11:46 PM
  5. Converting Baquacil to Bleach
    By supermom in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 05-19-2006, 05:50 PM
