Thread: Newbie lowering water level on above ground pool
    Default Re: Newbie lowering water level on above ground pool
    Not that I'm aware of.
    It would be possible to drain the pool, recut the skimmer hole through the wall panel, and liner . . . but that would make a mess of your liner and pool wall.
    I will say that neither of my boys really knew pools had bottoms till they were 8 or 9; they always swam in commercial pools that were too deep for them to touch bottom. It never kept them out of the water, and both became competitive swimmers. They both now swim Masters.
    I have to agree with Ben, do not mess with the pool. Use inflatables for a while, teach the kids to swim and problem solved. I raised four daughters in above ground pools. They loved every minute of that pool long before they could ever touch bottom. They all went on to swim team competition and a summer lifeguard job. We are a family of fish,
    But anyway, I have been asked a million times, how can I lower the water level for a few years? If you raise the sand base a foot, the bottom is so mushy and full of foot prints it is not worth it. If you lower the water level you leave that much more liner exposed to the sun and ready for dry rot. If you must drop the water level, put a metal plate over the skimmer and return openings, tape them in place. You can then go over top of the wall with a suction and return line. There are even over the wall skimmers that can be adapted to this type of situation.
    Hope this helps, Dennis
    Thx, Dennis.
    (I didn't know there were any guys besides my myself, whose families actually LIKE the water. Just about every pool guy I've known, hates pools and swimming!)
  1. How to re-level an above-ground pool after winter damage
    By Gr8dane in forum Above-Ground Pool Construction & Repair
    Last Post: 03-23-2014, 11:32 PM
  2. Ground or Sand Have to be Level Under an Intex Pool?
    By lancemwilliams in forum Intex-type Pool Setup & Operations
    Last Post: 06-28-2013, 09:40 AM
  3. lowering water in vinyl liner pool
    By maxhiller in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-04-2006, 12:31 AM
  4. Newbie: in ground pool recommendations
    By kmichelini in forum Pool Equipment & Operations
    Last Post: 07-20-2006, 04:07 PM
  5. Determing water level in ground before starting
    By tybeeware in forum In-Ground Pool Construction and Repair
    Last Post: 05-19-2006, 01:06 PM
