Results 1 to 10 of 13
Thread: First test with my Taylor K2006.
    Jun 2014
    A northeast state
    Default First test with my Taylor K2006.
    FC: 3.6, Combined: 0? (Sample did not change color when I added that reagent)
    pH: 7.4
    Alk: 70
    Cal: 150
    According to the chart I have a saturation index of .5.
    Should I raise my pH and Alk? I need stabilizer too. Hmm.
    Default Re: First test with my Taylor K2006.
    A CC reading of 0 is what you want. By the way, use the 10mL sample instead of the 25mL one as it will make your reagents last longer. Multiply the drop count by 0.5 instead of 0.2.
    Your pH and alk are ok where they are.
    What kind of pool do you have?
    (Ignore the book that comes with the kit. The kit is fabulous but the book ---- not so much. Just use instructions and info from the forum instead.)
    Jun 2014
    A northeast state
    The pool came with the house. I have no idea what brand. Its 15x30 and may possibly be a Namco brand. According to neighbors the homeowner bought it when the company was having a going-out-of-business sale.
    Kevin
    15x30 oval AG Pool. Hayward Power-Flo Matrix 3/4 HP pump. Hayward 16" sand filter. Taylor K2006 test kit.
    Doesn't matter what brand it is. I was trying to find out if it was an inground gunite pool as you would need to raise the calcium level if that were the case. Since it is an AG pool, that isn't necessary.
    One number you didn't list was CYA. Is this a freshly filled pool? Do you have a CYA reading?
    (Please update your signature to show that you have a K2006. You can do so by clicking on the link in my signature below.)
    Jun 2014
    A northeast state
    I didn't do a CYA test. Is it really that important? The pool is not freshly filled. It was here when we purchased the house.
    Kevin
    Yes, knowing your CYA is one of the 3 most important numbers along with chlorine and pH. Go ahead and run that test and report your number. We need to know that to know what your chlorine levels need to be. More about the chlorine/CYA connection here: http://pool9.net/cl-cya/
    Jun 2014
    A northeast state
    If CYA is stabilizer, then the number is 0. I know that without running a test. I don't have any and won't be able to get any until Wed. Working 12 hour shifts kind of puts a damper on getting anything done on work days.
    Kevin
    There may be some in there from last year. Probably a good idea to go ahead and run the test.
    Jun 2014
    A northeast state
    New numbers are in!
    Ch: 5.8
    pH: 7.2
    ALK: 70
    CYA: 60
    Going to go buy some stabilizer.
    Kevin
    You don't need more stabilizer. A reading of 60ppm is plenty.
  1. Taylor K2006 vs. test strip results
    By nefretrameses in forum DPD-FAS based testing
    Last Post: 07-24-2013, 08:04 PM
  2. Pool test smackdown: Taylor K2006, OTO, Pinch-a-Penny, Pool Store
    By famousdavis in forum DPD-FAS based testing
    Last Post: 07-25-2011, 11:47 PM
  3. amato ind and taylor k2006
    By bradc344 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-27-2010, 02:52 PM
  4. CYA Test with Taylor K2006 - CYA over 200!
    By ubalr1 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-08-2006, 09:04 AM
  5. Taylor k2005 vs k2006 kit
    By hancop in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-17-2006, 06:03 PM
