Results 11 to 13 of 13
Thread: First test with my Taylor K2006.
    Jun 2014
    A northeast state
    Default Re: First test with my Taylor K2006.
    Cool I guess all my number are good. Would explain why my pool is nice and clear. You all have been very helpful
    Kevin
    15x30 oval AG Pool. Hayward Power-Flo Matrix 3/4 HP pump. Hayward 16" sand filter. Taylor K2006 test kit.
    Just make sure that you keep your chlorine in range per the Chlorine/CYA chart I linked for you back in post #6. If you dip too low, you'll risk an algae bloom. (We call that chart our "Best Guess Chlorine Chart." If you lose that link, you can always find it in either my or PoolDoc's signatures.)
    One other comment -- use the 10mL water sample instead of the 25ml one. It will make your chlorine testing reagents last longer. You will multiply the number of drops by 0.5 instead of by 0.2.
    Glad we could help. If you need us again, you know where to find us!
    Jun 2014
    A northeast state
    Used wrong calculation for chlorine. My number is actually 14.5! I will hold off on adding chlorine for a day or so.
    Kevin
  1. Taylor K2006 vs. test strip results
    By nefretrameses in forum DPD-FAS based testing
    Last Post: 07-24-2013, 08:04 PM
  2. Pool test smackdown: Taylor K2006, OTO, Pinch-a-Penny, Pool Store
    By famousdavis in forum DPD-FAS based testing
    Last Post: 07-25-2011, 11:47 PM
  3. amato ind and taylor k2006
    By bradc344 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-27-2010, 02:52 PM
  4. CYA Test with Taylor K2006 - CYA over 200!
    By ubalr1 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-08-2006, 09:04 AM
  5. Taylor k2005 vs k2006 kit
    By hancop in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-17-2006, 06:03 PM
