Results 1 to 10 of 13
Thread: First test with my Taylor K2006.
    Default Re: First test with my Taylor K2006.
    Doesn't matter what brand it is. I was trying to find out if it was an inground gunite pool as you would need to raise the calcium level if that were the case. Since it is an AG pool, that isn't necessary.
    One number you didn't list was CYA. Is this a freshly filled pool? Do you have a CYA reading?
    (Please update your signature to show that you have a K2006. You can do so by clicking on the link in my signature below.)
    Jun 2014
    A northeast state
    I didn't do a CYA test. Is it really that important? The pool is not freshly filled. It was here when we purchased the house.
    Kevin
    15x30 oval AG Pool. Hayward Power-Flo Matrix 3/4 HP pump. Hayward 16" sand filter. Taylor K2006 test kit.
    Yes, knowing your CYA is one of the 3 most important numbers along with chlorine and pH. Go ahead and run that test and report your number. We need to know that to know what your chlorine levels need to be. More about the chlorine/CYA connection here: http://pool9.net/cl-cya/
    Jun 2014
    A northeast state
    If CYA is stabilizer, then the number is 0. I know that without running a test. I don't have any and won't be able to get any until Wed. Working 12 hour shifts kind of puts a damper on getting anything done on work days.
    Kevin
    There may be some in there from last year. Probably a good idea to go ahead and run the test.
    Jun 2014
    A northeast state
    New numbers are in!
    Ch: 5.8
    pH: 7.2
    ALK: 70
    CYA: 60
    Going to go buy some stabilizer.
    Kevin
    You don't need more stabilizer. A reading of 60ppm is plenty.
