Just make sure that you keep your chlorine in range per the Chlorine/CYA chart I linked for you back in post #6. If you dip too low, you'll risk an algae bloom. (We call that chart our "Best Guess Chlorine Chart." If you lose that link, you can always find it in either my or PoolDoc's signatures.)
One other comment -- use the 10mL water sample instead of the 25ml one. It will make your chlorine testing reagents last longer. You will multiply the number of drops by 0.5 instead of by 0.2.
Glad we could help. If you need us again, you know where to find us!![]()
