Re: Testing CC with K-2006
bottomcat
I just bought my first real test kit (K-2006) and tried to test Free and Combined Cl. I used the 25 ml sample size. Free Cl measures 1.0 ppm (5 drops R0871). When I tried to measure CC, I added 5 drops of R0003 and the sample turned a very light shade of pink. I then added two drops of R0871 and it turned clear (I thought) but a minute later it looked pinkish so I added two more drops. I turned clear again, but a minute later was light pink again. This went on until I had added a total of 7 drops and I finally quit.
Am I doing something wrong? Does the sample bottle need to be closed to keep it from turning pink?
Thanks in advance!
Not an expert here at all but re CC, I had the same experience with the liquid turning pinkish again when I waited some time. I don't think you need to worry about this. I believe the first time it turns clear when looking at the comparator tube from the side where you see the units (not from the top as it does look a different shade sometimes) is the one that matters. Let's see if the experts agree ;-)
In-ground 14K-gallon Pebble Sheen outdoor pool with 4-jet spa, Taylor K2006C testing kit, bleach chlorination, baking soda + muriatic acid for TA/pH adjustments, Hayward Ecostar SP3400VSP, Hayward H400FDN heater, Hayward DE6020 60-sqft DE filter, pressure-side Polaris 380 cleaner.
