Thread: Newby
    Default Re: Newby
    BBB is all about learning to take care of your pool by testing frequently and adding only what you need. In many cases, there are grocery store products that you can use instead of expensive pool store chemicals. I would suggest that you do a lot of reading here on the forum, especially the stickied threads at the top of a lot of the subsections. Also, read over on our sister website www.poolsolutions.com.
    Then, come back if you have specific questions that you need help with.
    Welcome to the Pool Forum!
    (By the way, until your registration is completed, you will have to log out first to be able to see the rest of the forum.)
