Results 1 to 10 of 17
Thread: New pool owner. Cya level over 100. No free chlorine detected....help
    Jun 2014
    Virginia
    Default New pool owner. Cya level over 100. No free chlorine detected....help
    Thank you so much for all the great info I've been reading so far about how to manage my pool. I have just tried to start caring for it using your techniques. I have my taylor kit on the way but it won't arrive until Thursday. In the meantime, I am relying on Leslie's pool store for my testing. I have a fiberglass pool, 8 k gal, paper filter cartridge.
    On Saturday here were the results:
    Fc 0
    Tc 0
    Cya 100
    TA 75
    Ph 7.7
    Phos 1000
    They told me to add 2#13oz alk up (I know it's baking soda but I bought it out of convenience) then do 1# chlor brite dichlor 4 hrs later. I immediately put in the baking soda but waited on the chlor brite.
    After reading your wonderful site, I knew the cya was a problem and further investigation about the di chor made me suspicious of using it. So I bought regular bleach at my grocery store and added it the next morning directly to the skimmer. I used about 1/2 gal. Since I didn't know the strength of it. Soon the pool took on a greenish glow. So I thought algae was starting...About 8 hours later I added a gal more of the bleach. Then the pool turned more green. My lousy test strips still showed no FC. So last nite, I added the chlor brite which cleared up the green. But my test strips still show no FC. I'm going to go the Leslie's again to test the water but I don think I trust them. Can you please advise me? I still have an association with a local pool service company who can come out with a phone call. Thank you so much.
    Lisa
    Frazzled new pool owner
    Default Re: New pool owner. Cya level over 100. No free chlorine detected....help
    While you are waiting on your kit, go to Walmart and see if they have the HTH 6-Way drops-based kit. (No test strips.) If not, get a cheap OTO/Phenol Red kit (yellow and red drops). Also, get a bunch of jugs of Walmart's generic 8.25% bleach and a bottle of distilled water.
    If you can find the 6-Way kit, it has a CYA test but it can't read over 100. (Neither can your pool store's test. 100 is the maximum reading that can be distinguished. So, your CYA may actually be a lot higher than that.) Take a cup of pool water and mix it with a cup of the distilled water and then use that for the CYA test but multiply your result by 2. Report back with that reading.
    In the meantime, add 3 of the 121-oz jugs of bleach. With a high CYA , it is going to take high chlorine levels to kill the algae. Don't use any more of the Dichlor since your CYA is already too high and that will make it go even higher.
    Report back with what kind of test kit you buy and with new numbers including the CYA level if you are able.
    Hope this helps.
    EDIT --- Rereading your post after I answered. I have a question that you should answer before you add that big dose of bleach in there.
    1) Was your pool green at all before you added the chlorine?
    2) Was your pool filled from a well?
    3) What does the water look like now?
    If the answer to question 2 is YES, then hold off adding the large dose of bleach.
    . . . membership upgraded.
    I also suspect metals in the water -- clean your cartridge (or at least look at it) and see what color the goo on the cartridge is.
    Jun 2014
    Virginia
    Thank you for the great information. Good news...the Taylor kit arrived and I was able to test myself. So here are the results:
    FC 0
    Ph 7.8
    TA 180
    Cya 160 (maybe...it was hard to discern)
    I added the 3 jugs of Walmart bleach 121oz size this evening. I will check everything again in the morning.
    Answering your additional questions:
    1. Pool was not green before adding the bleach over the weekend
    2. Not well water
    3. Water still looked clear and bluish before I added the 3 jugs this evening
    I didn't mention that it is an established pool which has been serviced by a local pool company for several years including last summer when we first moved in. I wanted to give caring for it ourselves a try since I live with 3 teenagers. We also added a solar hearing system to it..wow amazing! Got to 85 degrees in a few days and now stays there.
    Thank you PoolDoc...I don't know how to open the filter or backwash, etc but I will learn tomorrow when the pool service company comes. I suspect they never paid any attention to cya levels as previous owner had pool drained every spring for cleaning. I'm hearing they are lucky it never broke
    in two or cracked
    Lisa
    Less frazzled new pool owner
    6.3k gal FG inground pool with cartridge filter. Solid cover. Trichlor feeder, K2006. PF=19
    I have seen pools look green with very high TA -- though I've never been able to determine if that was cause or coincidence. I've also seen pools turn green with iron.
    1. Lower your pH to near 7.0 => http://pool9.net/ma/
    2. Watch the Taylor videos, so you can be sure you are doing the tests correctly:
    http://pool9.net/tk-guide/
    http://pool9.net/tk-interfere/
    3. Test and report your CH (calcium) level.
    4. Complete the pool info form:
    http://pool9.net/pf-pool-form/
    It isn't possible to get a CYA reading of 160 with the K2006 kit. 100 is the highest number on the scale.......
    Jun 2014
    Virginia
    Hi Watermom and PoolDoc,
    Thank you for your help. I watched the Taylor demos and filled out the pool form.
    Watermom, I did a you suggested and got a cya reading of 80 which I multiplied by 2 to get the 160 I reported to you. I'm not sure it's that high though. I had the pool company here this afternoon to show me how to work the pump, chlorination, etc. They tested too and got a cya reading under 100 but they don't always do that test so I'm not convinced that their number is correct. They also added some muratic acid and showed me how to siphon off water if I choose to do that. They had a FC reading of 5+ and TA of 150 approx. as they hadn't written them down. I will test again tomorrow and report all those numbers. The pool looks blue and clear but smells like chlorine a bit. No one is trying to swim so we can see how long the FC holds. Thank you again so much.
    Gotcha. I didn't realize that your CYA reading was from dilution. The fact that they got an FC reading of 5+ shows that your kit is better than whatever they are testing with. 5+ on a test kit that only goes to 5 means that it could be 5 or any number higher than that.
    When you post your numbers tomorrow, post FC and CC in addition to pH and TA. No need to run the CYA test again.
    Jun 2014
    Virginia
    Thank you. Here is what I got yesterday:
    FC: 8
    CC: .5
    PH 7.4
    Ch 270
    This chlorine ratio seems out of balance. What do you recommend?
    What is your TA reading? How does your water look?
    You are at the minimum chlorine level for your CYA. Take a look at this chart for more about the relationship between CYA and needed chlorine levels: http://pool9.net/cl-cya/ Go ahead and add some bleach now so your chlorine doesn't dip any lower through the day.
  1. Free Chlorine Level, too high?
    By mommak in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-07-2014, 01:43 PM
  2. how to get chlorine free level correct?
    By rajung in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-06-2013, 10:25 PM
  3. Very Low Free Chlorine Level.
    By jytchu in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-24-2013, 04:32 PM
  4. No Free Chlorine Level
    By dltodaro in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-08-2012, 06:41 PM
  5. Clear Pool but cannot maintain free chlorine level?
    By Mr.Mooks in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-20-2011, 08:47 PM
