Results 1 to 10 of 30
Thread: My cloudy pool
    Default Re: My cloudy pool
    It really doesn't work to try and combine pool store advice and ours. So, you kinda have to decide what you want to do. We are glad to help if that is the route you want to take but you really can't take a little of our advice and a little of their advice and make things work too well. Let us know. We'll be here to help if you decide to jump in and do BBB!
    Oct 2013
    PA
    I just thought someone might have a little insight as to why the pool would still be cloudy when the chemistry seems good. Some people claim to keep their sand for 20 years, others say it won't last 3, 5, or 7 years. Will a broken lateral cause cloudiness or just throw sand in the bottom of the pool? I also forgot to mention my furthest skimmer is sucking in air. Will I benefit more if I close it off, so no more air gets in the lines, or will leaving it open still filter more water?
    28000 gal. IG rectangular, vinyl lined pool. Pac Fab PF-50 sand filter. Sta Rite 1hp pump. Taylor K2006 test kit.
    What is your calcium hardness reading?
    Sand lasts indefinitely. It doesn't wear out.
    I'll let someone else address your mechanical issues.
    Oct 2013
    PA
    Calcium hardness was hard for me to tell being color blind, but I'm pretty sure it was around 40-50ppm. I can get a more acurate reading if needed. I heard hardness doesn't matter with a vinyl liner though. I'll put that in my Sig.
    The reason I asked is because high pH + high TA + high calcium hardness can = cloudy water. (Otherwise, you are right, CH is not an issue in a vinyl pool.) Have you been using cal-hypo for awhile? Maybe run that test again and let your wife read the results of it.
    Was your pool green when you opened it this spring?
    See if you can find a small bag of DE. Throw a handful into the skimmer while your pump is running and watch the return jets. If you see white powder shooting back out, your filter is not working properly. If it doesn't shoot out, then the DE may actually help your filter work a little better. More about that here: http://pool9.net/de-test/
    Oct 2013
    PA
    Yes, the pool was very green when I opened it. I was using the single lb. bags if shock so far. And baking soda to raise the ph. I tried a clarifier once but didn't want to keep dumping stuff in the pool. I did buy floc (again because of my wife, and the rumors she heard), but didn't throw it in because I just don't think it will help (according to this forum).
    Let us know when you try the DE test. Also, post current readings again. How does the water look today? Any better?
