Results 1 to 10 of 30
Thread: My cloudy pool
    Oct 2013
    PA
    Default Re: My cloudy pool
    Calcium hardness was hard for me to tell being color blind, but I'm pretty sure it was around 40-50ppm. I can get a more acurate reading if needed. I heard hardness doesn't matter with a vinyl liner though. I'll put that in my Sig.
    28000 gal. IG rectangular, vinyl lined pool. Pac Fab PF-50 sand filter. Sta Rite 1hp pump. Taylor K2006 test kit.
    The reason I asked is because high pH + high TA + high calcium hardness can = cloudy water. (Otherwise, you are right, CH is not an issue in a vinyl pool.) Have you been using cal-hypo for awhile? Maybe run that test again and let your wife read the results of it.
    Was your pool green when you opened it this spring?
    See if you can find a small bag of DE. Throw a handful into the skimmer while your pump is running and watch the return jets. If you see white powder shooting back out, your filter is not working properly. If it doesn't shoot out, then the DE may actually help your filter work a little better. More about that here: http://pool9.net/de-test/
    Oct 2013
    PA
    Yes, the pool was very green when I opened it. I was using the single lb. bags if shock so far. And baking soda to raise the ph. I tried a clarifier once but didn't want to keep dumping stuff in the pool. I did buy floc (again because of my wife, and the rumors she heard), but didn't throw it in because I just don't think it will help (according to this forum).
    Let us know when you try the DE test. Also, post current readings again. How does the water look today? Any better?
    Oct 2013
    PA
    So we triple shocked (84oz. of calhypo) Sunday night and got rain overnight, double shocked (56oz.) Monday night and got rain overnight, Tuesday morning I vacuumed and threw a single shock (28oz.) in because if the rain, and Tuesday evening my wife single shocked (28oz.) And more rain. Today (Wednesday), around 6pm, the readings were...
    FC=13.5
    CC=1
    pH=7.6
    All=150
    CYA=48
    Hardness was 150ish
    Pool is getting clearer, but stil has debri (dead algie?) on the bottom. I'll vacuum again in the morning. It's supposed to rain again tonight. Should I keep shocking until it's clear? Or should it be clear by now? Also, when doing the calcium harness test, I can see small particles suspended in the water. They seem to turn blue when the water does. Is that normal? Or is that what's causing the cloudiness? Thanks for the replies so far.
    You might want to start just using bleach instead of cal-hypo.
    You do need to keep shocking until two conditions are met:
    1) You can go from sundown one evening to within an hour of sunrise the next morning without losing more than 1ppm of chlorine AND
    2) You have no more than 0.5CC.
    Then, we usually advise keeping the chlorine high for one additional day for added insurance and then let it drift down and keep it within the proper ranges based on your CYA level. A chart that explains the connection between CYA and chlorine can be found at the following link: http://pool9.net/cl-cya/
    Have you tried the DE test yet so we can verify that your filter is working properly?
    Oct 2013
    PA
    I have not tried the DE. I haven't had a chance to get any. But I may wait because doesn't back washing clear out the DE? I'm constantly back washing from vacuuming. Will all the rain affect the chlorine level overnight? It's raining as I type. Can I use the sodium hypochlorite from the pool store, since I already have it, or just go to bleach? They're the same thing right? Just different concentrates?
