Results 1 to 10 of 16
Thread: Can't get rid of dead algae
    Jun 2014
    Summerville, SC
    Default Can't get rid of dead algae
    Hello! We have a 28ft above ground pool not a year old yet and we are having a bout with dead algae. We didn't cover it over the winter and got some green algae in it. Got that killed and we have vacuumed this pool about 7 times. We have done the floc out. All of our test strips are perfect. We went to the pool store this weekend and the guy sold us some cellulose fiber to make the particles bigger so the vacuum would pick it up. Now the pool is cloudy and he sold us copper algaecide. I'm so frustrated. Please any help would be appreciated. Thank you in advance.
    Default Re: Can't get rid of dead algae
    Stay out of that pool store!
    You don't want copper in your pool. Most people think it is chlorine that stains things and turns blonde hair green but.... it is copper!
    We'll need some additional info to be able to help.
    -- What size pump and what kind and size of filter?
    -- Exactly what all have you added to the pool, meaning ingredients and not just product names like 'shock.'
    We are going to need some good numbers taken with a drops-based kit. Guess-strips .... I mean test strips won't do it. The test kit that we think is by far the best is the Taylor K2006 or 2006C (better buy). Not available locally but you can get it through this link that takes you to Amazon: http://pool9.net/tk/
    But, in the meantime, go to Walmart and see if they have the HTH 6-Way drops-based kit (no test strips!) and get that. If they don't, get an OTO/Phenol Red kit (yellow and red drops) instead. Use it to test and then post your numbers. Also while you are at WallyWorld, get several jugs of their generic 8.25% bleach and a couple of boxes of 20 Mule Team Borax (laundry aisle).
    For now, don't add any more chemicals to your pool other than bleach to keep the chlorine up and Borax if your pH is low. Nothing else.
    Repost with requested info and then someone here can try and help you.
    Welcome to the Pool Forum!
    (Until you registration is completed, you won't be able to see the rest of the forum while you are logged in. So, copy that link and then paste it into a browser window after you log out.)
    Jun 2014
    Summerville, SC
    I replied to this yesterday but don't see it on here
    Maybe you typed it and forgot to hit submit. We've all done that a time or two! At any rate, there are no other posts from you. I just checked in the moderation queue and the one right above is the only one that was in there.
    Jun 2014
    Summerville, SC
    Lol I will post my readings when I get home but here's my story.
    3 weeks ago I went into pool store with a crystal clear pool. My only problem was what I'm thinking is dead algae on bottom of pool. They tested pool and said calcium was low. Bought and put in 25lbs of calcium. Pool guy also suggested and we bought this "pro magic phos free" system. One bottle to start up and then a maintenance bottle which you add 2 1/2 capfuls every week. Supposed to be guaranteed algae free or they GIVE you the chemicals to clear your pool. We vacuumed pool several times to waste. 2 weeks ago we went back to pool store bc we had a yellowish tint on bottom of pool and on steps (we never got dead algae out, it will not vacuum up) but water was still crystal clear. He GAVE us a bottle of copper algaecide bc we were on this phos free program and sold us a bag of cellulose fiber to put in our sand pump to help trap the small particles. Our pool went from crystal clear to you cannot see the bottom at all and we still have yellow on our steps and bottom of our pool. We did add 6oz of copper algaecide in the pool which I regret now after reading. After reading skme forums I added 4lbs of shock since Sunday. Pool is starting to clear but we still have the dirty look with yellow tint on bottom and steps.
    The pool is a 28x52 round vinyl pool ag
    Pump is sand filter sparco with a optiflo and it's the larger pump than what normally comes with the 24ft pools. I will post my chemical readings as soon as I get home. I did go and buy a drop test kit and did that last night and iffy number don't make sense I apologize. I am very very new to this. Thank you so very much
    Jun 2014
    Summerville, SC
    Ok my readings are
    Clorine 10
    TC 10
    BR. 6 (it said to x's this by 2 this is only one so x's two is 12)
    PH 8.0
    Total alk. 80
    Calcium hardness 230
    CYA. 90
    Is there anyway I can send a picture to show you how the pool looks and show you the color or the stuff on the step and on the bottom of the pool?
    You can use Flickr, Picasa, Photobucket, etc. to post pics.
    I assume your readings are from the HTH 6-Way kit. With chlorine over 5ppm, that kit cannot give you an accurate pH reading. Take 1/4 cup of pool water and mix it with 1/4 cup of distilled water. Then, run the pH test and report the reading.
    Don't use any more products in your pool at this point other than bleach. In most cases, and your pool is a prime example, all the stuff the pool store wants to sell you just makes the problem worse.
    You are going to need to run higher chlorine than 5ppm because of that CYA reading of 90. Take a look at this chart that shows the connection between CYA and chlorine. http://pool9.net/cl-cya/
    Therefore, you are going to need a kit that can measure those higher chlorine readings. If I am right that you have the HTH 6-Way kit, then you can buy the Taylor K1515 add on kit that will give the test that can do that. Having that test in conjunction with the 6-Way kit in essence gives you the Taylor K2006 kit that we typically recommend. You can find the K1515 through this link: http://pool9.net/tk/
    (Remember to copy the link and then log out and paste in a browser window. Once your registration is completed, you will be able to follow links without logging out first.)
    Also, ignore the bromine reading. You have a chlorine pool.
    Because of all of the concoctions that you unfortunately have put in your water, I'm going to ask Ben to chime in here on this thread and give his opinion as well. Don't do anything else at this point until Ben gives you his thoughts.
    EDIT --- Any idea how big your filter is (how many lbs. of sand) and also how big is your pump (what hp)?
    Jun 2014
    Summerville, SC
    The test kit I got was from Leslie's pool supply and it's a Taylor complete dpd test kit. It came with 14 different drops to test with. I paid $70.00 for it.
    The pump is a 1.5 hp pentair optiflo.
    The filter is sparco and I can't find the amount of sand in the filter anywhere. I would say 3-5 pounds.
    I can't retest the chlorine right now bc I did brush the pool tonight and put 5.5 bottles of Clorox in it. The pressure on the gauge is fine also. I did download flickr but not sure how to get my pictures to you from there.
    Does the chlorine test have you match colors of pink to determine the reading with 5ppm being the highest value on the scale? If so, that is the Taylor K2005. It is not quite the same as the K2006 (which can test much higher chlorine levels) but if you order the K1515 I mentioned above, you will have the missing test that you will need. It is an add-on kit so not as expensive.
    I'm pretty sure your sand filter doesn't use 3-5 lbs. At least I hope not! Most sand filter have between 100-350 lbs of sand. Is there a model number or something so we could look it up? The reason I am so interested in this is because unfortunately, I'm afraid you have a poorly matched filter and pump. You have a mighty big pump for a 24ft AG pool. In the case of pool pumps, bigger is NOT better. What happens is that when a big pump is paired with a small filter, instead of filtering well, the power of the pump simply forces debris through the sand bed and back into the pool. We see this all the time here on the forum. People think they are getting a good thing when they get a big pump but in reality, it is a problem. (Just to give you a comparison -- I have a 27ft AG pool and have a 1/2 hp pump paired with a 300lb sand filter.) It is much better to have a smaller pump paired with a large filter than the other way around.
    This mismatch makes it that much harder to clean up a pool so we'll have to keep our fingers crossed that your combo will get the job done.
    If you can't attach a pic, another option (though slower) is to email them to [email protected] and include your thread # (24371) in the email so the pictures can get posted in the correct thread.
    I have let Ben know that I would like for him to pop in on your thread, so hopefully he'll get to it before too long.
    Jun 2014
    Summerville, SC
    That made me laugh out loud. I told you I was very new at this. The test kit does make us match the color up after we have added the drops to it.
    Our pool is a 28ft x 52
    The pump is a optiflo 1.5 hp
    Sand filter is a sparco hi rate sand filter
    Serial#0518004130200m
    There's a number at the bottom 49269842
    P/n # 272526
    Container id is. Site E
    Date 1/4/2013
    I looked through all of my paperwork and can't find anywhere where it says how many pounds of sand.
    18k gal 28' x 52" AG pool, Sparco hi rate sand filter; Pentair Optiflo 1.5 hp. PF=7
  1. dead algae?
    By fresno49 in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-15-2013, 01:23 PM
  2. Cloudy with dead algae
    By amgarmon19 in forum Dealing with Algae & Slime
    Last Post: 04-23-2012, 06:57 PM
  3. how do i get rid of the dead algae
    By DirtRider67 in forum Dealing with Algae & Slime
    Last Post: 07-22-2011, 06:37 PM
  4. Dead Algae?
    By Tredge in forum Dealing with Algae & Slime
    Last Post: 08-07-2006, 11:01 AM
  5. is dead algae white
    By mspool in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-19-2006, 07:14 PM
