Re: Re-setting above ground pool on wet clay?
Hi, my rule of thumb is if I can walk across the area without sinking I can put a pool on it. If you are using sand for the cushion under the liner it should soak up a lot of the standing water. If you are concerned with the pool frame sinking you have some options. Instead of just putting blocks under the uprights, line the entire perimeter with block. It's a little more work but will keep your pool from shifting or sinking. Another option is to dig out the outer perimeter. Dig down 6" with a with of about 18". Fill this area with crushed granite or a crusher run. Pack it in good, set your post blocks and build the pool.
We have not had rain in months, where are you that it does not stop raining?
Later, Dennis
