Re: help....... any and all advice will be read
The dosing is in the recipe based on your volume. While it is filling, if you want to drizzle a little bleach in, that's fine. It shouldn't take long to fill up a 6400 gallon pool.
Pick up a cheap OTO/Phenol Red kit (yellow and red drops) at Walmart. You can use it to test your chlorine and pH now while you are using the recipe. Also, go ahead and order the K2006 as it will also test the other things you'll need but the OTO kit will still be used even then for quick daily checks.
Do you have the Dichlor and Borax yet?
