Results 1 to 10 of 26
Thread: Water testing and left over trichlo
    Jun 2014
    Bakersfield, CA
    Default Re: Water testing and left over trichlo
    New results entered
    Chlorine has stayed stable overnight. Unfortunately, with FC at 11ppm, based on your previous post I may be getting inaccurate pH readings.
    I had pool at about 15ppm on FC, but chlorine odor was pretty strong. I figure 11-13 is a decent number with CYA levels where they are.
    Sean
    15k gal concrete freeform IG pool, Sta-Rite PLM200 cartridge filter, Sta-Rite 3/4HP P6E6D-205L pump, feeding trichlor, 8hrs/day. PF=8
    There should not be any chlorine odor at 15 ppm UNLESS there's something in the water to still oxidize. As we speak, I have a heavily used 200,000 gallon local country club pool at 15 - 20 ppm FC . . . and the water is completely odorless.
    Jun 2014
    Bakersfield, CA
    Fair enough, I will continue to monitor.
    Sean
    Jun 2014
    Bakersfield, CA
    So, we did some make shift aeration this weekend. Seems as it had a small effect.
    Added 2 jugs of bleach after this test was taken.
    Sean
    ok. keep us posted.
    Jun 2014
    Bakersfield, CA
    Posted new test results.
    Added 1/2 gallon muriatic acid to reduce pH levels. According to this post http://www.poolsolutions.com/gd/lowe...p-by-step.html
    I am going to lower to 6.8 as this is the lowest my tester will go, I will then begin the aeration to lower the TA.
    How long should I wait before the next dose of acid to lower pH?
    Sean
    The aeration raises the pH, not lowers the TA. Don't drop the pH to 6.8 on your kit because by doing so, you don't know if 6.8 means 6.8 or any value lower. Lower it to 6.9 or 7.0 instead. You add the next dose of acid when your pH is raised back up to 7.6 or so.
