Results 1 to 10 of 20
Thread: cloudy water
    Jun 2014
    PA
    Default Re: cloudy water
    OK, I've been testing & adding 1/2 box of Borax at a time (as well as keeping chlorine levels up with bleach), & pH finally started to increase. As of this morning, here are the latest readings:
    FC 3.6
    pH 7.3
    TA 105
    CYA 100
    Chlorine has been holding fairly steady, & water is still blue, so I think algae is gone. It's still cloudy but I can see further down than before (about 2 feet). I do have a bottle of 60% poly algaecide which I've read in other posts can help. Do you think I should try it?
    22k gal 18x36 vinyl rectangle pool, Hayward DE filter, Hayward 1 HP pump, 8hrs daily, mesh winter cover, solar heat. PF=5.5
    A working DE filter is going to get all the particles -- by itself -- that polyquat or a stronger clarifer would help with.
    I think your best chance of cleaning the pool is to raise your FC to 20 ppm, and keep it there, till the pool clears. With a CYA=100, 20 ppm is NOT too high, even for swimming.
    By the way, use the 10mL sample with your K2006 -- you don't need to measure to the nearest 0.2 ppm -- and your reagents will last longer. Also, if you get full color with the first dropper of powder, you don't need to add a 2nd dropper.
    The OTHER thing you might do is to disassemble your filter (I assume it's a Perflex) and clean it fully. Unless the fingers have scale on them, simply spraying them off will be enough. Wear your OLD swim suit for this; it tends to be a nasty task.
    This video illustrates the task well, except for the fact that they are using a clean filter and recommend an un-needed proprietary cleaner. If you DO need to clean the filter, you can use an plain powdered laundry detergent + a cup of bleach. If scale is present, you WILL use muriatic acid 1 gallon to 5 gallons in the 2nd pass, but ONLY if there is scale and ONLY if you have first cleaned and degreased it. (Hayward manual)
