Results 1 to 9 of 9
Thread: New house, unwinterized pool
Threaded View
  1. #6
    Jun 2014
    Michigan
    Default Re: New house, unwinterized pool
    Hi Jason;
    If the filter is OK, it's large enough for your pool.
    I'd recommend the following steps:
    2. Get a cheap local OTO/phenol red drops kit (or an HTH 6-way drops kit, if available). Test the water. The main issue for now is whether the pH is between 7 and 8. If it's not, post your readings here.
    We have been a little busy with the new house, but I finally cleaned the pool a little, patched two holes and tested with the HTH 6 way for pH. It was above 8.2, I'm sure you have told many people what to do to get it back down so I will go search.
    Last edited by Watermom; 06-29-2014 at 08:31 AM. Reason: to make quoted text appear correctly
    18x32 liner pool, TA-60d filter
